JD 850 and bush hog
   / JD 850 and bush hog #1
redka
Middle GA
Can a JD 850 run a 6 ft. bush hog? Thanks
   / JD 850 and bush hog #2
Yes, but may just have to go slower in tall, thick stuff. Also may have to have some additional counter weight on the front end if lifting with 3 ph.
   / JD 850 and bush hog #3
I wouldn't.
I owned an 850, and if I remember right it was only 25/26 HP (22 PTO HP)
Mine would struggle in thick, deep grass with a 5' cutter. It handled a 6' belly mower fine.
   / JD 850 and bush hog #5
If it doesn’t have a loader you’ll probably want some suitcase weights on the front with either a 5’ or 6’ although the light front end does make it steer easy if it doesn’t have power steering.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2016 Chevrolet Impala Limited Sedan (A48082)
2016 Chevrolet...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2014 VOLVO VHD (A50854)
2014 VOLVO VHD...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
Ford Neon Sign (A48082)
Ford Neon Sign...
