JD 790 WON'T MOVE .........
   / JD 790 WON'T MOVE ......... #1
sriddle1
SW New Hampshire
ACTIVE: JDX730 DAYS GONE BY: JD3010, JD790, JD425
:confused: Was using my 790 w/FEL to set stone, you know, the typical New England stacked stone fences you see visitng New Hampshire, loading bucket with single stone at a time to easily set into place, up to 120 lbs. Shut the tractor down, parking brake on, took a short break, came out and started right up. Freely shifts into all gear pattern and nothing not-ta. No signs of grinding as I depress the clutch which was strong (so I thought, but what do I know) before my timely break, all the hydraulics work.. I'm thinking to myself, not a good day for stone fence work........ Told the wife on a positive note, didn't happen in the dead of winter. Any tips for me to further troubleshoot to understand better the issue before I tow it back up to the house...... THANKS
   / JD 790 WON'T MOVE ......... #2
I suggest pulling the top of the transmission off...I think your shifter linkage has come apart. Probably a roll pin worked loose.
   / JD 790 WON'T MOVE ......... #3
Could it be something as simple as the Hi-Low Range shift lever being in neutral?
   / JD 790 WON'T MOVE ......... #4
Boy, that would be embarrassing!
But I hope you're right!
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
Heavy-Duty Gooseneck Hay Trailer - Built for Large Bale Hauling (A53473)
Heavy-Duty...
2018 TY-CROP MANUFACTURING LTD DRY BULK PNEUMATIC TRAILER (A53843)
2018 TY-CROP...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
CONTAINMENT SKID MOUNTED (A53843)
CONTAINMENT SKID...
