Backhoe JD 790 backhoe clearance question
/ JD 790 backhoe clearance question #1
greyhound788
Anyone out there with experience using a backhoe on the JD 790? what's the clearance with the frame mounted backhoe?
many thanks, fred
/ JD 790 backhoe clearance question #2
Hi Fred, I have a #7 backhoe for my 790. The permanent subframe on the tractor runs from the loader brackets straight back to the rear axle housing. It is the same height as those two points along the entire length. It really doesn't reduce the clearance any as it is the same height as those points. The backhoe itself sits a bit lower and of course, greatly reduces your departure angle off the rear. There's a picture in this thread of my tractor with and without the backhoe, but I'm not sure you'll see what you need. If you want more info, including measurements let me know. My tractor is in the garage but I just tarped the backhoe for the winter /forums/images/graemlins/smile.gif
427893 (A61166)
427893 (A61166)
Headache Rack (A61166)
WOODS 3120 BATWING MOWER (A60430)
WOODS 3120 BATWING...
2026 Steel Pines Cargo 7x16 Enclosed Trailer, VIN#7FWBE1620T1037828 (A61166)
2026 Steel Pines...
20ft 2-Door Shipping Container (A61567)
20ft 2-Door...
2025 LandHonor DB-15-84W Hydraulic 84in 6-Way Dozer Blade Skid Steer Attachment (A60353)
2025 LandHonor...
