Backhoe JD #7 Backhoe Controls
/ JD #7 Backhoe Controls #1
EdMaine
I have a JD #7 backhoe on a JD 755. The conrol valves are leaking excessive hydraulic fluid from, I believe, the spool area of the controls. I am wondering if this is a repair job for an amateur such as myself? Are any special tools needed? Are there rebuild kits? Can you trade in controls for a completely rebuilt control set? Thanks for any help. ...Ed
/ JD #7 Backhoe Controls #2
I think it can be done, I've never rebuilt the spool valve assembly but I have had some of the ports open. It's mostly o-rings that are easily changed but you have too be careful of the ball bearings in the ports. Some are spring loaded and most have a cup they set in. Have you checked to see if the fittings are just loose? By the way, where are you located in Maine.
David
Thanks for the info. I am in Newport, Maine. I did tighten all parts without success. I bought the backhoe in 1988 and have worked it hard. I quess I am overdue for repairs. I am still debating if I want to tackle this repair.
/ JD #7 Backhoe Controls #4
When in doubt, have a pro look at it. I would get an estimate first. After the JD dealer I would try PRC hydraulics in Bangor on the Perry rd.
David
1997 Titan Gooseneck Trailer (A66285)
1997 Titan...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2020 ISUZU NPR 16FT BOX TRUCK (A59914)
2020 ISUZU NPR...
2013 GMC Sierra 2500 HD 4x4 Ext. Cab Pickup Truck (A64556)
2013 GMC Sierra...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
