Mowing JD 650 3pt mower ?
/ JD 650 3pt mower ? #1
briguy1957b
Central Ohio
JD 650
Hello everyone, I've got a question for you. I've got a JD 650 with an under belly mower deck. I've been thinking about getting a 3 pt mower for it to make it a little easier when i want to use my other attachments. I would like to get as big a mower as possible to cut down on mowing time. What size 3 pt deck do you think my 650 would handle ? I'd like to go to a 72" but i'm not sure it would handle it ok. Any thoughts ?
/ JD 650 3pt mower ? #2
I'm afraid 72" is out of the question for a 650. I think a 60" would tax the tractor pretty good. The 650 has 12-14 PTO horsepower at most? A 48" would probably be a good choice, although you could probably make a 60" deck work if you went slower.
Will
/ JD 650 3pt mower ? #3
IIRC, another thing to remember is that the 650 does not have a live PTO OR a 2 stage clutch so the mower will "drive" the tractor forward when you disengage the clutch unless you use an overrunning clutch on the mower.
What size is the current belly mower? I would not go bigger than that unless it doesn't lug easily with the current mower.
Dad had a 650 and a 60" belly mower on it but we never got to use it to see how it did w/ the deck. They were available with the 60" deck but that doesn't mean that it would work efficiently with it. I know with a 60" deck on my 2320 (18 PTO HP), I can pull down the engine in heavy grass.
Thanks for the replies guys. I've got a 60 inch under it now and would have liked to go bigger but no luck i guess. The 650 uses the 60 inch really well but i was concerned about a 72 inch 3 pt.
/ JD 650 3pt mower ? #5
I use a Frontier/Woods 60" 3 pt behind my 650 and it works fine. It is the rear discharge Woods painted green for JD model. Cuts great and the 650 handles it fine. It is definitly as big as I would run on the 650.
/ JD 650 3pt mower ? #7
"IIRC,"what does this mean I have seen it a lot lately? :confused:
IIRC....If I Recall Correctly...
A lot of us are getting to the age that we need to add that caveat...
/ JD 650 3pt mower ? #9
Glen W: Question for you (changing subjects)...you have a 6' AF11 (Frontier I presume). Do you use if for snow removal, if so what type of conditions, how well does it perform? Do you have any helpful thoughts or considerations on its set-up, use or performance?
Your thoughts are much appreciated.
/ JD 650 3pt mower ? #10
Yes it is a Frontier. It is not my primary means of snow removal but I have used it and it does work pretty good. It is a hydro turn and is very fast to use. The biggest issue I had was with the R4 tires. I have a lot of weight on the rear of the tractor. BB, Wheel Weights on loaded tires. I used to plow a good sized gravel driveway/parking lot that was also plowed by a pickup truck so it got a build up of snow/ice.Tires would spin real easy and the first pass had to be down hill. I would park it in the barn there which had concrete floors so I didn't want to run chains over the floors. Tire chains would have made all the difference though. Frontier used to sell these plows with long bolts to span the distance between the trip springs to make the blade rigid so you could use it as a dozer blade! Don't know how well that ever worked.I think that setup was just for pushing stone piles and like duty pushing. I also bought the plow with a rubber cutting edge on it but haven't used that.
/ JD 650 3pt mower ? #11
Thanks for your response. I added a rubber blade to mine and also have the long bolds for the rigid fit so between the two of those I hope to have good results. I am dealing with a 1,300' drive on all hard surface with some moderate incline on a portion. I also have R4's so it will be interesting to see how it does this winter. I am hoping that the rubber blade contributes to the success. Any other challenges or tips to be considered is helpful. Thanks again.
/ JD 650 3pt mower ? #12
I have a 650 with a 50 inch 3ph mower. I find it works fine, i can even bush hog some heavy stuff with it. heavy though, you would need some weights on the front
Hesston 3717 4 Basket Hay Tedder (A66408)
Hesston 3717 4...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
429888 (A61165)
429888 (A61165)
2013 International 4300 Bucket Truck 55' (A62613)
2013 International...
1992 Fontaine Trailer 44ft (A62679)
1992 Fontaine...
Steiner 450 (A64126)
