JD 613 gear box
/ JD 613 gear box #1
sparky
Nashville, TN
JD 5205
The gear box on my rotary cutter gave up the ghost yesterday. Trying to decide whether to replace the gear box or get a new (used) cutter.
1. Where is a good place to look for just the gear box? Have not found just a gear box searching so far.
2. The 613 was never really heavy duty enought for what I cut, 8 acres of rocky hill. The deck itself has been welded up several times! Suggestions on other decks to look at? I am not married to JD!
Thanks!
/ JD 613 gear box #3
Is it the bearings, seals or gears that went out.
idaho2
/ JD 613 gear box
The gears and bearings both are shot and of the 4 mounting points, three are cracked (have been for a long time). I suspect the box is cracked, the fluid leaked out and you know the rest. the deck is in pretty bad shape. If I could get a gear box for $ 500 or $600 that would work, I can weld up the deck. If not, I was looking for recommendations for better deck to begin with.
Thanks!
/ JD 613 gear box #5
Give me the SN# of the cutter and all the markings off of the gear box. I can help you out possibly.
/ JD 613 gear box
SN# W00613x018480. I dont see any markings on the gear box itself.
JD manual says it is a 45hp gear box.
/ JD 613 gear box
I young guy I work with might want this old piece of junk. Can anyone answer the question about a generic gear box? Why he couldnt buy a generic 45 hp gear box and not the expensive JD one? Are the output splines different on the JD?
2006 Lexus ES 330 Sedan (A61574)
2006 Lexus ES 330...
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
SET OF (4) METAL LOCKERS (A64281)
SET OF (4) METAL...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
