JD 5525
/ JD 5525 #1
DMBozeman
Kokomo, ms
John deere 5525
JD 5525 engine cranks but will not go into gear. No gauges will come on instrument panel. Fuse to key switch good
/ JD 5525 #2
"cranks" to some mean the engine is running, where to others it just means the starter turns the engine over but the engine will not fire up and run.
Yours sounds like the engine will run but just won't go into gear. Clutch not working maybe?
/ JD 5525 #3
So the engine is running, but no instrument panel. I assume you have a power reverser.
My guess is electrical and it has affected the interlock safety feature on the power reverser.
Check all wire and connections. Mice may have chewed through a wire...
/ JD 5525 #4
It was a blowed fuse in a separate lil fuse box on my 5425.
/ JD 5525 #5
Did you Figure it out ? :shocked:
2005 JLG G6-42A Telehandler (A62613)
2005 JLG G6-42A...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
2016 Nissan Altima Sedan (A61574)
2016 Nissan Altima...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2023 Chevrolet Express 2500 Cargo Van (A61573)
2023 Chevrolet...
