jd 5510 hydraulics
/ jd 5510 hydraulics #21
I also have a 5510 at 5500hrs with the powreverser and the same issue. New Clutches last year. When cold the hydraulics sometimes don稚 even respond (Steering, FEL, 3pt). It can take 5-10min to get minimal movement and still it is jerky and intermittent. Have you had luck in fixing your problem? I have changes the fluid, and filters with JD products and still the same issue. This only happens when cold though, right not the tractor is running fantastic.
JT
/ jd 5510 hydraulics #22
Cowski,
Did you ever figure what was causing this. My 5510 has about this amount of hours on it and is doing the exact same thing. I have seen multiple posts about this issue but not the resolution. Thanks
/ jd 5510 hydraulics #23
@txjim, there are 6-series tractors which have some kind of a feeding pump installed to feed oil to main pump.
Could this apply to those mentioned 5510' s as well?
/ jd 5510 hydraulics #24
I couldn稚 tell you. I seen in another post where Cowski installed a John Deere filter on an it fixed. Iエbe been running a Wix. I bought a Deere filter and put it on this morning. I also tightened it up with a strap wrench. The Deere filter recommended tighten the filter 1.25 turns after hand tighten. The Wix only wanted it hand tightened. I don稚 know if it is fixed yet or not but everyone I have spoken to says the tractor is sucking air on the suction side. There is only a filter, a couple of o-rings, and some hose clamps. I hope this fixes it. I really don稚 want to get into much deeper than the filter.
/ jd 5510 hydraulics #25
5510 which has open center hyd's has 1 hyd pump for hyd accessories such as 3 pt,scv & accessories such as FEL plus a pjggy back pump for power steering. Tractors I'm familiar with with a charge pump plus high pressure pump are closed-center hyd's. i will suspect a leaking suction hose or loose hose clamp.
/ jd 5510 hydraulics #26
When you say leaking suction hose are you thinking faulty oring? Or faulty suction tube itself. The tube is internal so I don稚 think that痴 the problem. I致e changed my filter and am still having this issue.
/ jd 5510 hydraulics #27
my jd 5510 hydraulics this winter are slow to work when the tractor is cold.after 30 minutes they mostly work fine.during the first thirty minutes they work real jerky or do not work at all.the tractor has over 3600 hours on it. i have changed the fluid,filter and cleaned the screen.it appeared to have a little fine break material in it.anyone have any ideas?
Having the Same exact issue....tractor mechanic says that the brake lining isxwearing off clogging filter and needs new break job. Did you ever figure out what was wrong with yours
/ jd 5510 hydraulics #28
Did you ever figure out what was wrong on your tractor....doing the exact same thing with mine and was told brakes need replacing.....would appreciate any input
/ jd 5510 hydraulics #29
Cut your filter open with a hacksaw and see if you have brake particles or any other foreign materials in it. My filter was clean but I was really hoping it wasn't the hydraulic pump. It turned out to be the hydraulic pump. I replaced it last winter and it worked perfectly as soon as I swapped it out. The other thing you can check before replacing the pump and it doesn't cost much of anything but time is the O-rings in the system. There are two in the Y-manifold that attaches directly to the pump on the bottom side. Also on the top side there O-rings on the out going lines. My hydraulics and power steering worked fine in the summer the only time I had an issue was when got near freezing. Best of luck.
/ jd 5510 hydraulics #30
I'll suggest to check/clean this screen if it hasn't been checked lately
my tractor always worked good in the summer. when the 5510 got to 4900 hours i changed the pump , that fixed it .
/ jd 5510 hydraulics #32
Anyone else with this issues have any solutions? has it been the pump with each of you having the same issues? My 5500 is doing the same thing.
Thinking low vis fluid would fix the issue, but don't want to change it every time the weather changes.
/ jd 5510 hydraulics #33
adc8693
Welcome to TBN.
Have you checked hyd level & checked/cleaned screen I posted a photo of in my post #30??????? If not then you should perform those tasks.
/ jd 5510 hydraulics #34
I have done both.
I may pull the screen again and make sure grime didn't kick up off the bottom of it. Even put a new relief valve in it (seem to help for a bit, but still doing the same thing now)
/ jd 5510 hydraulics #35
I have a 5410 that does this exact same thing. Hydraulics work great when warm but in winter it takes about 15 minutes before they work right. Effects FEL, 3 point and steering. I also notice my right brake pedal will bleed off when holding it down when the hydraulics are hot such as baling hay. I've changed hydraulic fluid several times using regular Hy-Gard and a John Deere filter each time and cleaned screen although it was not dirty. Thinking of replacing pump but would like to make sure that is the issue before dropping that kind of money hoping it fixes the issue. Tractor has 4500 hours on it, issue started around 2800 hours
/ jd 5510 hydraulics #36
Thorough hyd diagnostics should be performed before considering replacing hyd pump. Over the yrs many hyd pumps have been replaced only to determine that the replaced hyd pump was not the problem. I'll guess that whatever is causing hyd oil getting hot is what's contributing to faulty hyd pump operation
