JD 5420
/ JD 5420 #1
bigoak33
New London, North Carolina
360X
Got this 5420 and the 3 point hitch arms dont work! UP or DOWN removed an checked valve on side of transmission reinstalled an nothing still working....Anybody got any IDEAS. Oh yeah it has a cab on it too..
/ JD 5420 #4
Fluid level?
Did you check the mechanical part, what the lever is connected to?
Filter or screen that might be clogged? Do you hear pump cycling when you move lever?
/ JD 5420 #5
If you have steering and brakes, then the problem is the relief valve in the side of the rockshaft valve.
2018 SKYJACK  SJ843TH (A67714)
2018 SKYJACK...
2018 WILDCAT (A67714)
HYDREMA 912HM ARTICULATED DUMP TRUCK (A65056)
HYDREMA 912HM...
2006 FORD E450 UTILITY TRUCK (A66091)
2006 FORD E450...
2006 FRAC TANK 500BBL WHEELED (A68842)
2006 FRAC TANK...
2023 Unused Del Morino CS158M Agricultural Flail Mower Tractor Attachment (A66734)
2023 Unused Del...
