Loader JD 542 FEL - Timing Rod
   / JD 542 FEL - Timing Rod #1
DanielJ
Tyler, TX
John Deere 5625
John Deere 542 FEL has 2 main pins which the bucket assembly rotates up or down on. Between these pins (on the same axis) there is a 40" by 1" stainless steel rod pinned into 2 welded sockets. It is called a Timing Rod. I tore mine up on a stump. How critical is this rod and what is its purpose??
Thanks.
Dan Johnson
   / JD 542 FEL - Timing Rod #3
How bad is yours damaged? Can it be fixed, maybe srtaightened with a press? I would want it repaired.
It is bent but can probably be straightened with a press. I agree that it should be repaired. Thanks for the help.
   / JD 542 FEL - Timing Rod #6
i bent mine years ago.been meaning to straighten it,just had not got around to do it.since i have been running without one for years ,i don't think it is necessary.
   / JD 542 FEL - Timing Rod #7
Might be cheaper to replace the rod than to have it straightened. I had to replace the timing rod on my 400X FEL a few mos ago (broke where pin goes thru) and it was around $140 for the new timing rod.
   / JD 542 FEL - Timing Rod #8
I've had mine bent periodically over the years by rocks and stumps. My dealer straightens it out each time for $40-50. In fact mine could use straightening again....Gary
   / JD 542 FEL - Timing Rod #9
Hello: I saw your link to an article on the JD site about the JD 542 FEL timing rod. I tried to follow the link, but it just takes me to the main JD Service and Support page. I haven't been able to find the article. Do you know how we can access it?
Thank you for any help!
vickers
   / JD 542 FEL - Timing Rod #10
Please see attachment, not the best of quality to read, but that is all I have.
  • timingrod.pdf
VOLVO A40E OFF ROAD DUMP TRUCK (A52707)
VOLVO A40E OFF...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2007 Pierce Dash Truck (A55973)
2007 Pierce Dash...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2023 John Deere 332G Skid Steer (A53485)
2023 John Deere...
