Loader JD 542 FEL - Timing Rod
   / JD 542 FEL - Timing Rod #11
That's what we were looking for.
Thank you!
   / JD 542 FEL - Timing Rod #12
I bent my very bad and I went to a machine shop and bought a 48" long 1" diameter cold roll steel rod and made it a one piece assy. It has worked for seven years and no problem. I did drill the hold the pins that keeps the rod in place. Mike
John Deere 542 FEL has 2 main pins which the bucket assembly rotates up or down on. Between these pins (on the same axis) there is a 40" by 1" stainless steel rod pinned into 2 welded sockets. It is called a Timing Rod. I tore mine up on a stump. How critical is this rod and what is its purpose??
Thanks.
Dan Johnson
2008 KENWORTH T300 (A58214)
2008 KENWORTH T300...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2016 FREIGHTLINER...
1983 INTERNATIONAL S SERIES WATER TRUCK (A52707)
1983 INTERNATIONAL...
2023 Kubota M5660SUH Compact Utility Tractor with LA115-4 Loader (A56435)
2023 Kubota...
2014 VOLVO A25G OFF ROAD DUMP TRUCK (A52709)
2014 VOLVO A25G...
Sellick 560 Forklift (A57148)
Sellick 560...
