Loader JD 542 FEL - Timing Rod
   / JD 542 FEL - Timing Rod #1
DanielJ
Member
Tyler, TX
John Deere 5625
John Deere 542 FEL has 2 main pins which the bucket assembly rotates up or down on. Between these pins (on the same axis) there is a 40" by 1" stainless steel rod pinned into 2 welded sockets. It is called a Timing Rod. I tore mine up on a stump. How critical is this rod and what is its purpose??
Thanks.
Dan Johnson
   / JD 542 FEL - Timing Rod #3
How bad is yours damaged? Can it be fixed, maybe srtaightened with a press? I would want it repaired.
It is bent but can probably be straightened with a press. I agree that it should be repaired. Thanks for the help.
   / JD 542 FEL - Timing Rod #6
i bent mine years ago.been meaning to straighten it,just had not got around to do it.since i have been running without one for years ,i don't think it is necessary.
   / JD 542 FEL - Timing Rod #7
Might be cheaper to replace the rod than to have it straightened. I had to replace the timing rod on my 400X FEL a few mos ago (broke where pin goes thru) and it was around $140 for the new timing rod.
   / JD 542 FEL - Timing Rod #8
I've had mine bent periodically over the years by rocks and stumps. My dealer straightens it out each time for $40-50. In fact mine could use straightening again....Gary
   / JD 542 FEL - Timing Rod #9
Hello: I saw your link to an article on the JD site about the JD 542 FEL timing rod. I tried to follow the link, but it just takes me to the main JD Service and Support page. I haven't been able to find the article. Do you know how we can access it?
Thank you for any help!
vickers
   / JD 542 FEL - Timing Rod #10
Please see attachment, not the best of quality to read, but that is all I have.
  • timingrod.pdf
2021 International HV507 4x4 12ft Single Axle Dump Truck (A55852)
2021 International...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A54814)
2016 Ford F-550...
Brent 420 Grain Cart (A55314)
Brent 420 Grain...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Fork...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
