JD 5415N
/ JD 5415N #1
DLTTrekkers
Paarl South Africa
Engine oil disappeare to the radiator. From the highmark to under minimum in less than 10 min .
Where can I look for the problem ?
Engine sounds and starts fine .
/ JD 5415N #2
5415N appears to be incorrect model #
/ JD 5415N #3
If you're getting oil in your radiator could be a head gasket.
/ JD 5415N #5
Well.....thats what the sticker on the bonnet tells me ! I am in South Africa.
You are referring to a JD? I was thinking engine oil in radiator caused by leaking engine oil cooler. PS: I knew your profile stated S Africa as your location & JD parts site is world wide.
/ JD 5415N
Green paint with JD stickers on sold by JD agents.....looks to me with a Carraro gearbox.....all green.
/ JD 5415N
It is a N.....for narrow . The configeration is not in q.....problem with the engine . Please help me with that ?
/ JD 5415N #13
Then there should be water in oil ?
Depends on where it blows and where the pressures are. Could possibly be a crack in the head or block as well, if it's near where oil pressure is, that is under more pressure than the coolant system and that's why it's not getting coolant in the oil.
/ JD 5415N #14
Ditto leak could be leading to combustion chamber & coolant going out muffler
/ JD 5415N #16
Is it a wet sleeve engine? Could be a liner failure and leak oil into coolant. But that fast, quite unlikely.
/ JD 5415N
I ordered some parts and 1 off them came with a short bolt with lock-tite on it. Mybe that s my problem ?
/ JD 5415N
I went and tested this tractor this morning and no oilleak to the radiator.
I do beliefe that the locktite on that 2 short bolts did the trick.
/ JD 5415N #19
Thanks for update. I'm glad you got it repaired.
Jim
OK TRAILER  16 FOOT TRASH TRAILER (A68842)
OK TRAILER 16...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
CHECO GREASE UNIT (A67714)
CHECO GREASE UNIT...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
2015 GMC SIERRA 3500HD CC (A67714)
2015 GMC SIERRA...
