JD 5303 Tachometer Intermittent
/ JD 5303 Tachometer Intermittent #21
I am having similar problem with the tachometer, when accelerate the engine the needle move down to zero.
As of late everything is working except the hours are not advancing. Occasionally it takes the tachometer a minute to begin working, but has not failed to start working and appears to be accurate.
/ JD 5303 Tachometer Intermittent #23
On my 5310 it was the fuel gauge that quit. I replaced the fuel sender but that didn't do it. After I traded it the guy that bought it made the dealer fix the problem, it was the gauge cluster.
I have checked all I can find to check and stopped just short of replacing gauge cluster. I average 100-125 hours annually. Hours not advancing is not a huge issue, but do like to have all functions working. May try replacing cluster at some point.
/ JD 5303 Tachometer Intermittent #25
I've read and experienced quite a bit about those models of tractors. The gauge cluster is a failure item along with starters and the cold temp thermistor.
I am 2 for 3 of those items. No starter issues yet.
2025 IRANCH IREAS Wood Grab Grapple Mini Excavator Attachment (A61572)
2025 IRANCH IREAS...
2016 Ford Explorer (A61574)
2016 Ford Explorer...
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59912)
2019 ISUZU NPR 4X2...
John Deere 635F 35' HydraFlex Grain Head (A64119)
John Deere 635F...
Danuser 3pt Auger (A64119)
Danuser 3pt Auger...
Caterpillar 330BL Excavator Service and Parts Manuals (A63117)
Caterpillar 330BL...
