JD 5303 Tachometer Intermittent
/ JD 5303 Tachometer Intermittent #21
I am having similar problem with the tachometer, when accelerate the engine the needle move down to zero.
As of late everything is working except the hours are not advancing. Occasionally it takes the tachometer a minute to begin working, but has not failed to start working and appears to be accurate.
/ JD 5303 Tachometer Intermittent #23
On my 5310 it was the fuel gauge that quit. I replaced the fuel sender but that didn't do it. After I traded it the guy that bought it made the dealer fix the problem, it was the gauge cluster.
I have checked all I can find to check and stopped just short of replacing gauge cluster. I average 100-125 hours annually. Hours not advancing is not a huge issue, but do like to have all functions working. May try replacing cluster at some point.
/ JD 5303 Tachometer Intermittent #25
I've read and experienced quite a bit about those models of tractors. The gauge cluster is a failure item along with starters and the cold temp thermistor.
I am 2 for 3 of those items. No starter issues yet.
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
2014 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR8EH765283 (A61165)
2014 International...
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A62130)
UNUSED CFG...
UNUSED MGY-100KW FUEL HEATER (A62131)
UNUSED MGY-100KW...
UNUSED KJ 23'X22' DBL GARAGE METAL SHED (A62131)
UNUSED KJ 23'X22'...
Hydraulic Mini Excavator Attachment (A61567)
Hydraulic Mini...
