JD 5220 No Start ?
   / JD 5220 No Start ? #1
Alpine7
Dayton TN
JD5220,MinMolineZ,FarmalA,KubotaFZ2100,Speedex24
The Fuel Lines Were Cracked And Leaking On My 01 JD 5220
Replaced The Main And Return Lines, Water/Filter Sep.
Having A Hard Time Bleeding The System, Was Worried I Sliped Some Contaminents By. J.D. Manual Says To Remove Bolt From Side Of Injection Pump. Work The Plunger At The Filter Housing Till Fuel Flows From Hole Without Bubbles. Cant Seem To Get Flow!! It Will Slowly Seep Out On Its Own.Pumping Makes No Diff. Pulled Loose The Line To Pump,Fuel Flows Great.
How Much Fuel Is To Run Out Of Hole? Seep or Flow ?Do I Need To WD40 For A Self Bleed Run. Cracked A Line to Injector No Fuel Presure.Looked In Inlet Area For Clog Seemed Very Clean. HELP !!
Thanks Arnie :confused:
Kubota L4701 (A53317)
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
2007 KUBOTA KX121-3 SUPER SERIES EXCAVATOR (A60429)
2007 KUBOTA...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
