JD 5210 engine died and can't get it started
/ JD 5210 engine died and can't get it started #1
Tx Jim
New Member
Coyote Flats,Tx
JD 4255/Kubota M7040 HDC
My neighbors JD 5210 engine died and won't restart. It has good fuel flow from tank to filter housing but NO FUEL will pass through NEW FILTER and out bleeder. Can hand(primer) pump block flow? Air will blow out bleeder but no fuel. Fuel cutoff on filter body is open. Thanks,Jim
/ JD 5210 engine died and can't get it started #2
Got the correct filter ?? How do you know ?
Filter came direct from JD RE60021 Filter Element ADD 21.81 USD
/ JD 5210 engine died and can't get it started #5
JD5210
Thanks for the video. Well neighbor blew out the orifices in the filter housing and got fuel through housing and ""engine running"". He didn't see any obstruction but something was preventing fuel flow to inj pump. Thanks for everyone's help.
Jim
