JD 5105 fuel issue
   / JD 5105 fuel issue #1
Birddog Dave
NW Florida
JD 5105
so I had a primer diaphragm blow a hole. Finally got the correct primer assy. I installed it this morning. Tractor primed up and ran fine for 10 minutes. Cutting at WOT. Then it just shut down like I turned off ign switch. I can shoot fluid in the intake and it will run on that. Seems to be primed to the sediment filter. I replaced the can filter behind the valve cover prior to installing new primer and sediment filters. Fuel line is new.
Is there a fuel shut off fuse or the like? Any input is appreciated.
   / JD 5105 fuel issue #2
Couple of things come to mind 1.Fuel line obstruction where the line comes out of the bottom of the fuel tank. 2.Fuel shut off solenoid
I have 12v at all fuses except the Alt and fuel solenoid.
Is there a relay or any idea where this breakdown may be and getting voltage to that fuse?
Where are my grounds for the alt and fuel solenoid on the engine?
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
1991 Grove RT740B 40-Ton Rough-Terrain Crane (A51691)
1991 Grove RT740B...
