JD 5085M power reverser flashing N
   / JD 5085M power reverser flashing N #51
Power Reverser Switch
   / JD 5085M power reverser flashing N #52
IF the fuses & Seat Switch are ok : I think it’s the PR Switch Most of the time.
Especially if the PR has been used a lot and / or over 3-500hrs on it.
   / JD 5085M power reverser flashing N #53
Jbain, I took a gamble on a new $240 Power Reverser Switch & it fiXed my 5093E.
Old one had water in it & contacts were wore slam out.
I'll check it out if the boot Is cracked or worn out it would be the second boot to do so. The other boot was the shifter boot.
Thanks,
   / JD 5085M power reverser flashing N #54
I'll check them my tractor has 220 hours. Thanks,
   / JD 5085M power reverser flashing N #56
How many hours on your Tractor ?
Is the rubber boot around Power Reverser Switch Handle Stem torn or broken ?
The grease dries up inside the PR Switch & the brass contacts wears making the F&R Solenoids not get power then the trans speed sensors sees no movement then kicking on the dreaded red neutral light & Alarm.
220 hours.
   / JD 5085M power reverser flashing N #57
My 2012 5085M does it too, but when it does, I just put the power reverser in neutral for about 10 seconds and it clears.
In my case it only happens when I'm a little aggressive and switch from forward to reverse (or visa versa) a little too quickly.
Does anyone of you have has or has had a 5085m know how to get the codes to read on the 的nformation Display? My model does not have the roll mode switch.
   / JD 5085M power reverser flashing N #59
   / JD 5085M power reverser flashing N #60
Does anyone know where the Neutral Relay is on a 5083/5093E ?
The Fuse panel lid says it’s in the center console.
I can’t find it unless it’s behind the instrument cluster in dash.
Hello
I have the identical problem.
Did you ever find out where the center console relay is located ?
2016 Troy-Bilt 21in Push Mower (A55973)
2016 Troy-Bilt...
2023 WRANGLER 5500T ARTICULATED WHEEL LOADER (A58216)
2023 WRANGLER...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
JLG 1255 Telehandler (A56436)
JLG 1255...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
