JD 5085M power reverser flashing N
   / JD 5085M power reverser flashing N #1
ajd4339
Kentucky
John Deere 5085M
I have a 2010 JD 5085m lately it's got to where the N light will flash when you put it in forward or reverse. Usually you can just flip it back to neutral and it will stop flashing then it's good to go. This time it just keeps flashing no matter what it do. Any suggestions?
   / JD 5085M power reverser flashing N #2
My 5093E doing same thing
What was the fix ??
   / JD 5085M power reverser flashing N #3
The tractor is "neutralizing" itself. I would check the relay first.
   / JD 5085M power reverser flashing N #4
A relay n fuse box for PowerReverser ?
A friend told me to change Hyd Filter as a sensor is recognizing low fluid pressure.
IDK. Seems like elc issue to me.
It'll flash red light & beep & kick out of gear while backing up just fine.
It was in the power reverser lever. Had to have a new one. Not cheap!!!
   / JD 5085M power reverser flashing N #6
I thought my PR switch may be it too BUT it immediately turns the red warning light & beeper ON every single time regardless of direction & will not pull.
I can eventually get it to take gear but it may go 10 or 100ft then quits pulling when Neutral light & PR red light flashes.
   / JD 5085M power reverser flashing N #7
My fuse box label on inside of metal cover doesn't seem to match my Dual Fuse boxes on my 5093E open station & my manual book is no help.
Does anybody have a Schematic Pic ??
   / JD 5085M power reverser flashing N #9
My 5055E did this a while back.
It ended up being a blown fuse. I don't remember which one it was on the schematic, but I just started pulling out all of them and checking them and eventually I found a blown one.
   / JD 5085M power reverser flashing N #10
Mine works fine when engine / Hyd fluid is cold.
Problem happens after normal temp is reached.
I drained Hyd fluid, changed filter & cleaned sump screen.
It takes gear a lot faster & raises 3ot hitch quicker now but I doubt this fixed it.
