JD 5085M power reverser flashing N
   / JD 5085M power reverser flashing N #31
Do you have the part number for the lever? I have a 5055e doing the same thing. It is driving me crazy.
Mine must have been a loose connection on one of the solenoids on left side of transmission.
It hadn't acted up since I re-secured all the elc plugs there.
I have a New PR Lever switch assy just incase though :D
   / JD 5085M power reverser flashing N #32
I unplugged/plugged my connections with no change. Do you have the part number for the switch assembly? I've looked through the parts catalog and its clear as mud what part is needed.
   / JD 5085M power reverser flashing N #33
Part # RE200375 fits my 5093E open station.
Not sure on your 5055E 3cyl.
   / JD 5085M power reverser flashing N #35
I appreciate the response. I have gone through every connection I can find, so hopefully it is the switch. Especially since I'm about to spend $300 on a replacement.
   / JD 5085M power reverser flashing N #36
I figured I could throw parts at it like a JD shop w/o the labor.
I'd say thers no DTC's in system so they'd be clueless lol
   / JD 5085M power reverser flashing N #37
It hadn't acted up since I re-secured all the elc plugs there ...
Scratch that, 18months later I’m getting the dreaded neutral light & Alarm while going along fine in A1.
Wouldn’t take F or R.
I had to pull it & implement back to the barn & swap tractors.
Tried it again the next day & it would take Forward but Not Rev.
New Pressure Sensor On left side of Trans didn’t fix it.
I hadn’t checked for loose fuse yet.
Any ideas ?
   / JD 5085M power reverser flashing N #38
Mine turned out to be the switch. I checked it by using a friend of mine's switch off of his tractor. I put his switch on mine and everything worked. My switch on his and he had the same problem. Easy fix--took forever to track down.
   / JD 5085M power reverser flashing N #39
I get the red neutral light AND alarm every single time I shift into F or R
So I’d ASSume the Switch is working but I’m guessing lol
   / JD 5085M power reverser flashing N #40
It's been too long. I can't remember if I got an alarm as well.
2008 Mercury Milan Sedan (A56859)
2008 Mercury Milan...
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
2007 Ford E350 (A55973)
2007 Ford E350...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
2015 Ford Focus Sedan (A56859)
2015 Ford Focus...
