JD 5045D hydraulics will not work.
/ JD 5045D hydraulics will not work. #1
coaldust
Wolfe City, Tx
John Deere 5045
Tractor only has 112 hours on it but 10ys old. I had bucket pointed down with most of the front weight on the ground trying to scrape dirt backwards, heard a "POP"
and the control would only move the bucket very slowly the quit all together. I pulled all four cylinders and checked operation with compressed air, found one of the main lift cylinders stuck. I had a hydraulic shop repair it, reassembled everything and bucket moved one cycle slowly all the way up and tilted bucket up and down, bucket lowered slowly then would not work any more. I removed the bucket and was able to raise bucket arms about 2 feet by working the control lever on and off and it would move a few inches at a time until it stopped at the 2ft level.
Yes, the fluid level is good.
Any ideas??
/ JD 5045D hydraulics will not work. #2
I suggest to begin hyd diagnosis with simple things such as installing new hyd filter & checking hyd system pressure to be sure pressure is correct. Does 3pt hitch operate correctly? Tractordata shows pressure @ 2828 psi
PTO along with power steering do not work.
Should I remove and inspect the filter screen in the gear box along with changing the filter??
/ JD 5045D hydraulics will not work. #4
Yes check & clean hyd oil suction screen if it needs cleaning
2016 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A64279)
2016 CATERPILLAR...
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
BG PF5 HIGH OUTPUT POWER FLUSH AND FLUID EXCHANGE SYSTEM (A65643)
BG PF5 HIGH OUTPUT...
John Deere 2755 Boom Mowing Tractor (A66285)
John Deere 2755...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
