JD 4630 Won't Start
/ JD 4630 Won't Start #1
Farmer Frank
JD 4630 JD 4020
I changed the oil, started the motor, cheked level, a little high, so I drained the oil filter. The tractor would not start again. It rattled the first attempt, then nothing. When I turned the key as to start, the other gauges would "hump up"(move a little in the opposite direction). I cleaned all the ground and othe connections on cables and starter. I found a small crack on the starter solinoid(Noponso starter and selonoid, Not JD)I orderd a new solinoid. Could this be the problem? I have always had to disconnect the left ground and the hot to the starter or the batteries would discharge. The batteries were charged and showing 14 volts. I was getting 13.8 volts at the starter terminals. Any suggestions? Also I did not mark all the connections on the solinoid when I removed it, does any one have a diagram so I don't short it when I install the new one? It was back ordered and has been over 3 weeks and my memory may not be what I thought it would be when I removed it! :(
/ JD 4630 Won't Start #2
I have been putting together a general list to answer this question. Hopefully it will give you some places to look.
Nothing happens when you turn the key
- Check battery under load
o Lights dim when turning the key is a classic symptom of a battery going bad.
- Check all starter connections (including grounds) for corrosion and tightness
- Check fuses
- Safety switches (seat, PTO, neutral switch)
- Make sure in Park/Neutral HST pedals in neutral position/centered
- Make sure you have power at the starter/solenoid
- Make sure starter and solenoid working
Starter IS working
- Do not run the start for more than 20 seconds
- Make sure intake is clean
- Do you have smoke coming out of the exhaust
- Water in fuel ?
- Glow plugs not working
No smoke from exhaust not getting fuel
- Make sure you have fuel in the tank
- Loosen fuel cap, tank may not be venting correctly
- Replace fuel filter
- Check fuel line for holes as this can put air in the line
- Check fuel line not clogged (both supply and return)
- Check that fuel tank not clogged at the bottom
- Bleed tractor check manual for how to do this
- Bleed injectors
Smoke from exhaust getting fuel
- Bleed injectors
Wow! Sounds like I have some work to do. I'll get going on it. Thank you.:thumbsup:
/ JD 4630 Won't Start #4
It is not as bad as it looks, just wanted to cover all the bases. Sounds like you have already done a few things, so you can check them off.
Please let us know how it goes.
/ JD 4630 Won't Start #5
Frank
If your battery voltage is correct,all 6 battery connections are clean & tight then I'd check the neutral(safety) start switch on RH side of trans case for continuity.
/ JD 4630 Won't Start #6
does anyone know what sort of battery you need for a 4630? i have just bought one but the battery was shot, it only have one and i guess its a 12 volt. any suggestions?
/ JD 4630 Won't Start #7
Aussie
:welcome:
There are two 6 volt batteries, as listed in jdparts.
TY21735 DRY CHARGED BATTERY QTY 2 6-VOLT, 850 COLD CRANKING AMPS AT -18°C (0°F), 280 MINUTE RESERVE CAPACITY AT 25 AMPS, (SUB FOR AR47455 OR TY6119)
Maybe there has been some tinkering to change to a 12v system. ??
My 4630 has two 12 volt batteries, one on each side. Mine wouldn't start because there was a short in the starter. BTW, those two batteries need to be fully charged and all hot and ground connections very clean. She will "snort" if she has plenty of umph.....
100 Gal Fuel tank/tool box combo (A65643)
100 Gal Fuel...
2004 Chevrolet Silverado 2500HD (A66408)
2004 Chevrolet...
Landhonor RGB-11-72, 72" Rock Grapple  (A62679)
Landhonor...
2013 FORD F-150 (A65643)
2013 FORD F-150...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
John Deere 2 Row Planter (A65640)
John Deere 2 Row...
