JD 4610 No Start. Baffled
/ JD 4610 No Start. Baffled #1
rkncirclec
WA
JohnDeere 4610
I have a JD 4610 PowerReverser/Diesel/RearPTO.
When I turn the key, it just clicks, does not start.
Knowns:
a) Starter Motor and engine work (we jumped the starter and fired right up); died in gear
b) Battery charged.
c) Plenty of diesel
Tries:
a) replaced all fuses
b) replaced Diode Blocks
c) replaced starter relay, engine relay and neutral relay
d) replaced transmission switch
e) replaced rusty seat switch
Flowing Cranking Circuit operation page 150 in tech manual.
She's stuck out in the pasture; don't dare getting my truck stuck to get'r back in.
Any tips on next steps would be appreciated. It still feels like an interlock issue.
Thanks
Ben
/ JD 4610 No Start. Baffled #2
What do you mean,`died in gear'? don-ohio
/ JD 4610 No Start. Baffled #3
Sounds like a ground issue of some type . Make sure they are clean and tight .
on PTO switch continuity tests:
OFF positions all pass
ON positions don't. (could be the culprit)
receded the PTO. She fired up.
2016 WEILER P385A ASPHALT PAVER (A63276)
2016 WEILER P385A...
2020 KENWORTH T60 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 KENWORTH T60...
(1) UNUSED 8.3-24 TIRE W/ 6 LUG RIM (A64280)
(1) UNUSED 8.3-24...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2019 CATERPILLAR CP54B PADFOOT ROLLER (A62129)
2019 CATERPILLAR...
6' ROTARY MOWER (A64280)
6' ROTARY MOWER...
