JD 4610 No Start. Baffled
/ JD 4610 No Start. Baffled #1
rkncirclec
WA
JohnDeere 4610
I have a JD 4610 PowerReverser/Diesel/RearPTO.
When I turn the key, it just clicks, does not start.
Knowns:
a) Starter Motor and engine work (we jumped the starter and fired right up); died in gear
b) Battery charged.
c) Plenty of diesel
Tries:
a) replaced all fuses
b) replaced Diode Blocks
c) replaced starter relay, engine relay and neutral relay
d) replaced transmission switch
e) replaced rusty seat switch
Flowing Cranking Circuit operation page 150 in tech manual.
She's stuck out in the pasture; don't dare getting my truck stuck to get'r back in.
Any tips on next steps would be appreciated. It still feels like an interlock issue.
Thanks
Ben
/ JD 4610 No Start. Baffled #2
What do you mean,`died in gear'? don-ohio
/ JD 4610 No Start. Baffled #3
Sounds like a ground issue of some type . Make sure they are clean and tight .
on PTO switch continuity tests:
OFF positions all pass
ON positions don't. (could be the culprit)
receded the PTO. She fired up.
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
3 Point Bale Mover (A65640)
3 Point Bale Mover...
KUBOTA KX057-5 EXCAVATOR (A65053)
KUBOTA KX057-5...
2025 IRET13 Electric Tricycle (A64194)
2025 IRET13...
2022 EZ-GO ELITE...
