JD 4610 Codes
   / JD 4610 Codes #1
stevesmill
Noblesville, Indiana
2001 JD 4610
Can someone tell me what it means when my code light flashes; short , short, long, short. Everything seems fine but this flashing bothers me. Thanks in advance.
   / JD 4610 Codes #2
on the 42,43,4410 it means -
   / JD 4610 Codes
Thanks. I can't tell any difference in the performance. Do you suppose it's the same with the 4610?
I don't show any info like this in my owner's manual. Is there a service manual that I have to buy?
   / JD 4610 Codes #4
Contact your Deere dealer for the service manual. Always a good idea if you plan to do your own maintenance...
Sounds like you may have a bad sensor (or the connecting wiring) though...since you don't have any other symptoms.
   / JD 4610 Codes #6
Hey steve at the mill - is your cruise control working??? if not one of your speed sensors is toast - i've posted on it. let us know:)
   / JD 4610 Codes
I never really use the cruise control, so I'm not sure if it works or not. I will try it 1st chance I get. Thanks for your help.
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
2019 PJ  40FT GOOSENECK TRAILER (A58214)
2019 PJ 40FT...
