JD 4610 Codes
/ JD 4610 Codes #1
stevesmill
Noblesville, Indiana
2001 JD 4610
Can someone tell me what it means when my code light flashes; short , short, long, short. Everything seems fine but this flashing bothers me. Thanks in advance.
/ JD 4610 Codes #2
on the 42,43,4410 it means -
/ JD 4610 Codes
Thanks. I can't tell any difference in the performance. Do you suppose it's the same with the 4610?
I don't show any info like this in my owner's manual. Is there a service manual that I have to buy?
/ JD 4610 Codes #4
Contact your Deere dealer for the service manual. Always a good idea if you plan to do your own maintenance...
Sounds like you may have a bad sensor (or the connecting wiring) though...since you don't have any other symptoms.
/ JD 4610 Codes #6
Hey steve at the mill - is your cruise control working??? if not one of your speed sensors is toast - i've posted on it. let us know:)
/ JD 4610 Codes
I never really use the cruise control, so I'm not sure if it works or not. I will try it 1st chance I get. Thanks for your help.
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
2007 John Deere 1790 Planter (A63111)
2007 John Deere...
2020 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2020 Ford F-150...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
1068 (A63291)
1068 (A63291)
207273 (A52708)
207273 (A52708)
