JD 455 pto speed?
/ JD 455 pto speed? #1
Bowhunter
southwest Indiana
Kubota BX2200
My dad has a 455 garden tractor and a 445 rotary tiller (54" pto driven). I have a Kubota BX2200 and am hoping to find a pto adapter that will let me hook up the pto shaft to my tractor. My tractor has a regular male end on the tractor, while the tiller's pto shaft also has a male end.
My question is does anyone know the pto speed of this tiller? I know some cat. 0 equipment runs at 1000 rpm. My tractor runs at 540 rpm. I want to make sure I'm not wasting my time finding an adapter if the speeds don't match. Thanks.
/ JD 455 pto speed? #2
Bowhunter,
The 455 PTO speed is 540. Go to a farm supply store and find a female PTO adapter.
Good Luck.
Kevin
/ JD 455 pto speed?
Thanks Kevin, that's what I wanted to hear. /forums/images/graemlins/laugh.gif I'm pretty sure I saw a female adapter at out local Rural King.
/ JD 455 pto speed?
After searching Rural King for a female to female adapter, and the local JD dealer for either an adapter or the tractor end of a pto shaft that would work.....I came up empty. Does anyone know of a place online that sells adapters?
/ JD 455 pto speed? #5
Why not just put a female end on the tiller? You should be able to find one at a farm store. It may involve replacing a u-joint, which can be exciting.
Kevin
/ JD 455 pto speed? #7
I had the same 450 tiller drive shaft problem when I traded my 455 for an X495. I ended up having to buy an entirely new drive shaft from my local JD dealer. I hope you have better luck finding an adapter than I did, the drive shaft with a clutch was about $300.
/ JD 455 pto speed? #8
Pretty sure the part you are looking for is BM17757. It is a male stub on both ends, which fits into your tractor and then will hook up to normal 540 PTO implements.
Anytime you want to research this kind of stuff, Stonehams is a great place to start.
/ JD 455 pto speed? #10
He needs just the opposite, female/female.
16ft Equipment Trailer (A65579)
16ft Equipment...
(6) 4ftx12ft platform grating  (A62679)
(6) 4ftx12ft...
1,000-gallon Stainless Tender Tank (A66408)
1,000-gallon...
2025 60in Bucket Skid Steer Attachment (A64553)
2025 60in Bucket...
Auger Cart (A65640)
Auger Cart (A65640)
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
