JD 450E tracks
/ JD 450E tracks #1
ch47dpilot
Enterprise Alabama
09 Kubota L3400
The tracks on my 450E dozer are stiff. Only a few can be moved up/down by hand. I think it may just be rusty. Local JD dealer said they've had some luck with driving dozer and pouring old oil/hydraulic fluid on the track as it rolls. Anybody done this or have other tricks.
/ JD 450E tracks #2
We used a hand held pump sprayer with pb blaster (1 gal can) and diesel fuel. on a excavator.
/ JD 450E tracks
Where did you get on blaster by the gallon. Did you mix it with diesel or spray them separately. After spraying did you just let it soak or did you drive right away to get tracks flexing. If soaked first how long.
/ JD 450E tracks #4
Hi I think napa auto parts mixed 1 gal pb 2 gal diesel sprayed moving slow back and forth then again let it soak You have to run it to get the tracks loose ,spray it over nite then run it
2014 Honda Accord Coupe (A61574)
2014 Honda Accord...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
HARDEE 200 GALLON POLY TANK SPRAYER, 3PT (A63291)
HARDEE 200 GALLON...
2021 Ford Explorer AWD SUV (A61574)
2021 Ford Explorer...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
2013 FORD F250 (A60460)
2013 FORD F250...
