JD 450E tracks
/ JD 450E tracks #1
ch47dpilot
Enterprise Alabama
09 Kubota L3400
The tracks on my 450E dozer are stiff. Only a few can be moved up/down by hand. I think it may just be rusty. Local JD dealer said they've had some luck with driving dozer and pouring old oil/hydraulic fluid on the track as it rolls. Anybody done this or have other tricks.
/ JD 450E tracks #2
We used a hand held pump sprayer with pb blaster (1 gal can) and diesel fuel. on a excavator.
/ JD 450E tracks
Where did you get on blaster by the gallon. Did you mix it with diesel or spray them separately. After spraying did you just let it soak or did you drive right away to get tracks flexing. If soaked first how long.
/ JD 450E tracks #4
Hi I think napa auto parts mixed 1 gal pb 2 gal diesel sprayed moving slow back and forth then again let it soak You have to run it to get the tracks loose ,spray it over nite then run it
2007 FREIGHTLINER CL112 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59912)
2007 FREIGHTLINER...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
9 SHANK CHISEL PLOW (A63291)
9 SHANK CHISEL...
PALLET OF GLASS (A63291)
PALLET OF GLASS...
2018 Ford E-450 Shuttle Bus (A61573)
2018 Ford E-450...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
