JD 450 bottom rebuild cost
   / JD 450 bottom rebuild cost #1
milkie62
upstate NY
Kubota M6800,Ford 801,MF 65, Kubota L305
I have been looking at JD 450 dozers for my property. 2 driveways to build, 3/4 mile of wood road to maintain and 2 houses to build along with playing on my 100 acres doing food plots and things. My price range is in the low $20k range. I plan on taking a Cat mechanic from my FD to look at anything I may want to buy. If I find something in the 50% UC what is involved in bringing it up to the 90-100% UC range ? What parts are changed ? Can it be done at a home shop or does some need to be farmed out ? Hope I am asking the right questions.
   / JD 450 bottom rebuild cost #2
It can get costly depending on how many parts are worn out drive sprockets ,front idler , track links (chain), bottom rollers, You can do it at home but its a lot of bull work, You could get a price quote from a dealer for parts and labor, Then price out aftermarket parts and your time... GG on here ( TBN)did his dozer maybe he will chime in........
   / JD 450 bottom rebuild cost #3
track chains can have bushings turned if they have not already been done. That job takes a shop with a special track press ---some of them are 500 ton jobbers. as far as all of the other parts --- you can do that at home with a LOT of hefty friends to help.
If the chains are really worn---cheaper to get new ones and have something that will run a long time. sounds like you plan on putting a lot of hours on it so I wouldnt cut corners on parts to start with. just my .02
I have approx. 100 acres that a little over half is wooded. A couple of logging roads to access firewood. My kids will be building homes so grading, septic , driveways, will need to be done. I also have about 1800' of hedgerow that I would like to reclaim by pushing out the brush and rebuilding the stone wall. Renting or having someone do it a little at a time would cost too much. I am retiring in march and want to play more. I was thinking $20k price for dozer and maybe up to $7k for doing u/c myself for the most part. About 100 hrs per year initially then just some property maintenance after that. Figure 450 size is good for what I want to do--no major earth moving but would need a 6 way blade for side hill wood road work. Want to make my field edges and one long hedgerow park like . Also a nice little metal carport for longetivity after steam cleaning and paint.
Also does anybody know if winches can be put on the rear of most dozers ?
2011 Toro Workman HD Gas Utility Cart (A59228)
2011 Toro Workman...
2010 KMC 3376 Peanut Combine (A56438)
2010 KMC 3376...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
1959 DODGE D510 DUALLY FLATBED TRUCK (A60430)
1959 DODGE D510...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
EXCAVATOR JACKHAMMER (A58214)
EXCAVATOR...
