JD 445 Sputtering when up to temp
/ JD 445 Sputtering when up to temp #1
PC66
Waukesha, WI
John Deere 445
Greetings, hoping someone out there can help me out. I have a JD 445 with a 22 Kawasaki EFI. First time I've had this issue, once it runs for 20-30 min the engine begins to sputter, it won't die, even with PTO engaged, but gets close. If I shut down the motor, wait 5-10 seconds, it will run fine again for 15-20 minute before the problem returns. So far I've changed the plugs, coils and caps and fuel filter. I've seen other posts that this may be a fuel pressure regulator issue or possibly the MAP sensor, any help is appreciated!
1967 Hyster C35T-3 Equipment Trailer (A66285)
1967 Hyster C35T-3...
STIHL HT250 POLE SAW (A64276)
STIHL HT250 POLE...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
Unload Auger Tube for John Deere Combine (A65640)
Unload Auger Tube...
2022 EZ-GO ELITE...
2023 Ford F-350 4x4 Flatbed Truck, VIN # 1FTRF3DM5PEC15665 (A65563)
2023 Ford F-350...
