JD 445 Sputtering when up to temp
/ JD 445 Sputtering when up to temp #1
PC66
Waukesha, WI
John Deere 445
Greetings, hoping someone out there can help me out. I have a JD 445 with a 22 Kawasaki EFI. First time I've had this issue, once it runs for 20-30 min the engine begins to sputter, it won't die, even with PTO engaged, but gets close. If I shut down the motor, wait 5-10 seconds, it will run fine again for 15-20 minute before the problem returns. So far I've changed the plugs, coils and caps and fuel filter. I've seen other posts that this may be a fuel pressure regulator issue or possibly the MAP sensor, any help is appreciated!
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
2021 Soil Warrior 4500 (A63116)
2021 Soil Warrior...
2016 VOLVO EC250EL EXCAVATOR (A64279)
2016 VOLVO EC250EL...
KBH Tender Trailer (A56438)
KBH Tender Trailer...
Muck-Truck Wheelbarrow (A61567)
Muck-Truck...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
