JD 4400 splitting
/ JD 4400 splitting #1
jordan4400
john deere 4400 with 420 front loader
hi new here and after some advise ect
so the front drive shaft seal is leaking and theres a fair bit of play in the shaft up and down side to side so i ordered seals bearings clips the lot
im pretty handy with tools thats not the issue, my issue is finding the correct procedures on splitting the tractor and then order of how to replace bearings and seals
replacing 19 18 17 16 20
thanks jordan
/ JD 4400 splitting #2
I would think that it would be easier to move
the axle forward than splitting the tractor but
then again I never worked on a tractor just
thinking
willy
/ JD 4400 splitting
unfortunately to replace the seal the tractor has to be split, you just cant get in there with anything and the seal wont come out due to the casing covering the lower part
/ JD 4400 splitting #4
Too bad they don't make tractors easy to
work on
willy
/ JD 4400 splitting #5
Just be careful splitting. I've split some big ones. Get weights and loader off front half. I usually roll front part away from back part, leave rear stationary. Block rear wheels so no rolling. Put a jack under rear and Jack under front. I put my front jack on a base with wheels. It is the bottom of an engine crane. I take crane apart and use base when I split a tractor. Floor jacks are too much of a pain with the handle. My base has four steel casters.
/ JD 4400 splitting #6
I had to split our 4300 to replace the HST linkage. PDF copies of the manual can be had for $40 or so. You may want to fab some splitting jacks. Here is a pic of the set I cobbled together from steel scraps, allthread, and some HF casters. The front end jacks mount to the floor frame mounting pads.
/ JD 4400 splitting #7
Jordan, check your messages
24in excavator tooth bucket (A61307)
24in excavator...
2020 BOBCAT MT55 STAND ON SKID STEER (A63276)
2020 BOBCAT MT55...
2015 RAM 1500 4 X 4 CREW CAB PICK UP TRUCK (A59914)
2015 RAM 1500 4 X...
27x32 CIH Rim (A65640)
CHANDLER 10' STAINLESS STEEL FERTILIZER SPREADER (A64277)
CHANDLER 10'...
Woods 72" 3Pt Mower (A66408)
Woods 72" 3Pt...
