JD 4320 power steering
/ JD 4320 power steering #1
Davo
mid CT
JD 4320
Anyone have a 4320 and hear a whining noise coming from the power steering? I don't know if it's one of the hydraulic pumps working extra hard or what. I just got it in August so it's a bit different than my 4200. Maybe it's a normal noise. Just wondering.
Thanks
/ JD 4320 power steering #2
I have a 4320 and I do hear a whine. I'm not sure it was the PS, I'll try to listen for it more closely.
/ JD 4320 power steering #3
My steering causes whining also, sometimes louder than other times. I believe it is normal, the hydraulic pump is being utilized for power assist. My 4320 is in the shop right now for warranty work, so if there is something not right, I am sure the mechanic will notice and correct it. I am not used to hydraulic noises, especially from the hydro. I always had gear tractors before this, and they only had gear whine from the transmission, not the hydraulics.
/ JD 4320 power steering #4
Yep,mine to, 4520,i've read here that most do whine.Thats the 4000 twenty series anyway.
Mike
Thanks guys. Here I thought I had a problem and it's a normal thing. or we are all having the same problem /forums/images/graemlins/wink.gif. For michiglenn I had a 4200 for 4 years with a ehydro and never got a hydraulic noise from it. So i think this is unique to this series. Lets hope it's normal boys.
michiglenn what is your machine in the shop for? Anything i should look out for?
/ JD 4320 power steering #7
Davo,
Nothing serious. Innacurate fuel gage, a noise in the rockshaft when lifting, the inside of the instument panel bezel has some streaks of liquid on it, one front tire loses air, and a couple of other things I can't recall. I have been writing down little things for a couple of months, and I figured winter would be the best time for both of us to have them work on it. With over 200 hours on it, any bugs should have been noticed by now. It has been such a good tractor I feel guilty for bringing it in on such piddly things, but I paid good money for it and the dealer has been known to do more than expected when brought in for warranty work (powerwashing, fluid and filters, etc., n/c). That's one of the reasons I bought a Deere, they are generally going to make sure you are satisfied and will want to keep doing business with them. I am planning this one will last my lifetime and probably my kid's, too.
/ JD 4320 power steering #8
O yea,my 4520 needs to have the gauge fixed also.acting erratic.The only two problems i have had ,has been fuel gauge & cracked battery around the top seam and leaking acid. Mike
I'll be sure to check my battery and guess what guys? I replaced my fuel guage sensor also.
/ JD 4320 power steering #10
Mine only makes noise when my backhoe is off . When it makes noise you can feel it in the steering.
Jim
/ JD 4320 power steering #11
I contacted my dealer with a similar problem,(but no whining) he claims the whining isnt normal. told me to listen out for that.
/ JD 4320 power steering #12
My 4720 has a vibration in the steering that creates a whine like noise. There is a technical bulletin out for this noise, but mine already has all the updates. The noise is louder when it is cold outside. If I grab the wheel and keep it from moving - the noise goes away. Oh well, I cna live with it.
I think my battery is leaking also - I see some rust on the front of the frame - where acid migth have leaked. Always something...
D.
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
Case Titan 3530 (A63688)
Case Titan 3530...
2021 Bobcat T76 (A64126)
2021 Bobcat T76...
UNUSED WOLVERINE RIPPER (A64281)
UNUSED WOLVERINE...
2006 Freightliner M2 106 24ft. Box Truck (A61573)
2006 Freightliner...
Rotary Auger Motor Attachment (A61572)
Rotary Auger Motor...
