JD 4310 no lights
/ JD 4310 no lights #1
YesDeere
Merland
Have not done any investigation yet just wondering if anyone has had this problem. Would have looked at it but my generator crapped out. Bad night.
Anyway. Have flashers and rear work lights. Just no dash lights and headlights. Will investigate in the morning.
Thanks
/ JD 4310 no lights #2
Haven't had that problem ...yet. But I'd start with the usual suspects. Fuses and making sure everything's plugged in.
Did you drive it through a creek or anything?
/ JD 4310 no lights #4
If the fuses are good, next place I'd look is the light switch itself...get's pretty dirty under there. Remove and reconnect all the bayonet connections and see if that works.
/ JD 4310 no lights #5
Should be a pretty simple solve. Start at the fuse if fuse is not blown than pull out the test light or the multimeter. Next make sure you power coming into the switch than out of the switch. Fortunately the lighting circuit is pretty basic so it shouldn't be too difficult.
/ JD 4310 no lights
Finally got time to look at it tonight. Well, I turned the switch and they worked. So fuse is obviously good but I checked to see if it was loose or corroded. All good.
Could not re create it by wiggling switch either. Now I am sure it will not happen again until it's dark and snowing. Strange
Anyway I think I will pull dash cover and switch to clean it. Then I will finally adjust the parking brake switch that plagues these models.
Thanks for the responses.
/ JD 4310 no lights #7
Glad it's working...not so glad that you don't know what caused it. I hate those kind of problems. I either try to ignore them or go nuts and start taking random things apart.
How do you adjust the parking brake switch? My light will stick on sometimes if I've set the parking brake. It will go off as soon as I release it but will pop back on occasionally after a few minutes of driving. I'll stop and pump the brake pedal a few times and that will usually clear it but it may come back on a couple more times.
/ JD 4310 no lights #8
Give the fuse for that circuit a "wiggle" and see if it happens again,
they get oxidized sometimes.
2022 EZ-GO ELITE...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2015 Audi A4 Sedan (A61574)
2015 Audi A4 Sedan...
2008 Ford Expedition SUV (A61574)
2008 Ford...
2006 Volvo VNM T/A Day Cab Truck Tractor (A61573)
2006 Volvo VNM T/A...
