JD 4300 won't crank
   / JD 4300 won't crank
have 12v at starter. how do you short this starter across to make it run? I know you're not supposed to but I want to know if it is the problem.
Ok I figured out how to hot wire starter and it started after cranking one turn. (Placed big rock on seat in order to engage seat safety switch). I'm not sure what this tells me i.e. bad safety switch somewhere, key switch bad, bad relay, etc.? Any ideas on what to do next? I really need a wiring diagram in order to try and figure this out - where can I get one?
One other thing - I bought this tractor used with 400 hours but the owner had lost the owners manual - I have searched this tractor over looking for the place to check the hydraulic oil and all I can find is the fill plug right behind the seat. Where the heck is it?
   / JD 4300 won't crank #13
I have a 4100 CUT that has similar symptoms right now (parked out in the pasture). I think it's related to the "must be in neutral" safety switch.
It's a HST, and even though it's in N, I think that "it" thinks it's still in L. It acts the same way.
The 'seat switch' acts like it's running -- meaning when I turn on the ignition switch, if I stand up, the seat switch pops a relay (even though it's not running). If it was in N, I don't think the seat switch would matter. You can start the tractor in N while not sitting on the switch.
I was facing slightly uphill, and I think while in L, I stood up and killed it. Somehow, I think it's electronically "stuck" in L, even though I move the lever from L-N-H back to N. I think I'm going to put it into N and tow it about a yard and see what happens.
   / JD 4300 won't crank #14
Had a problem like this on kubota b2400, turned out to be common to that model, used a J.D. part no. AM107421, I bought and installed it after dealer wanted to put in a new starter and ignition switch, $340.00 This is a low voltage relay, easy to install, under $30.00. Might be able to go to Kubota thread for B2400 starting problem and look for Kubmech's explanation of this (7/15/04) Has to do with decreased voltage reaching starter solinoid due to increased resistance in starting circuits as parts age. Good luck.
   / JD 4300 won't crank #15
On my 4100, it now works.
I has to be something with the neutral sensor. I towed it forward 10' or so and put it through H-N-L and back to N. Then some raising/lowering of the seat and jostling of levers and it started.
To start it has to be in N. You do not need to be in the seat. The brake does not need to be depressed.
   / JD 4300 won't crank #16
You can get both at your JD dealer. The FSM(factory service manual) on CD is a wonderful thing to have. They cost under $100 for your machine.
The owners manual can be downloaded HERE from the JD site, click the "view" link on the right.
Finally, I found the problem. It was the "nuetral" sensor. They put it right under the floor platform with the wires coming out the top and the platform is actually pressing against the wires. Some "genius" designed this, because there is no way to get the plug or sensor out without taking the whole platform off. Luckily with just a little movement mine started working, how long I don't know, but at least I know where the problem is. Thanks to all who gave advice and helped me track this down.
   / JD 4300 won't crank #18
Wallfarmer,
My 4310 has a sight glass for checking the hydro oil. It is near the rear PTO shaft. I don't know for sure but I'll bet that is where yours is too.
I thought the same thing when I got my 4310!!
Thanks, that's where it is! Appreciate the help.
   / JD 4300 won't crank #20
Wallfarmer,
On the 4300 the sight glass is on the left side of the PTO shaft.
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
2014 FREIGHTLINER CASCADIA (A50854)
2014 FREIGHTLINER...
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2018 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2018 Ford F-450...
2007 PETERBILT  385 CAB AND CHASSIS (A50854)
2007 PETERBILT...
