JD 4210 - bogging down ?
/ JD 4210 - bogging down ? #1
kidsdad5
Burnt Hills, NY
Kubota BX2200
I have a new to me 2003 4210 with ehydro trans - 815 hours. It's bogging down going up a small incline while mowing relatively short grass. The indicator light is flashing 3 short and one long. Is this something electrical? It also slows down a bit even when not mowing, not as bad, and I don't get the indicator lights unless I am mowing. Confused and hoping there is an easy remedy?
Thanks
/ JD 4210 - bogging down ? #2
Are you familiar with all the different ehydro settings on the 4210?
I am not anymore, but recall that some of them can be a bit confusing and conflicting.
:welcome: to TBN
I am still trying to learn all the ehydro settings, yes they are somewhat confusing to me too. Thanks for the link to that thread, missed that one when I attempted a search. Since I have no idea what a potentiometer is (I do now after researching) I'm probably going to have to contact a dealer. Reading that info leads me to believe it's not something I can repair. Hopefully I can find an ehydro settings combo that will work. Thanks for the replies. If anyone else has other thoughts or ideas I would appreciate hearing them. Thanks
/ JD 4210 - bogging down ? #5
kidsdad
What gear range are you mowing in, when you sense the lack of power?
beenthere - I was in B. I also tried C and it did the same thing.
/ JD 4210 - bogging down ? #7
Will have less HP in high "C" range, should have more in "B" range and more yet in "A"
"C" is only for road travel.. no engagement of attachments.
Are you using "load match" ?
Also look for something causing more load.. bearings? grass or wire wound around spindles? brake dragging?
Thank you. Will spend some time reading my manual in detail tonight. I just got the tractor and started cutting grass............Something tells me the brake may be sticking, pedals and park brake seem to function in an odd manner. Tomorrow I'll check these and the other items you mentioned. Love the help found on this forum. Thanks again
/ JD 4210 - bogging down ? #9
I personally don't like the "long arrow" mode at all in the little I've driven a 10 series. It make the transmission feel like it's being controlled with a rubber band. The short arrow is much more responsive.
/ JD 4210 - bogging down ? #10
The 4210 was underpowered, but the 4310 was not bad. I have the next generation (3x20) and there is no power in range C--transport only. A or B only for using the PTO or engaging ground. Also the torque curve peaks around ~1700 rpm, so if you are dragging under there you definitely will feel a power drop-off.
/ JD 4210 - bogging down ? #11
Which is the whole point and why they give you a choice.
Long/Short Arrow is the 'Rollout' which is the time taken for the tractor to coast to a halt after you take your foot off the pedal (in either direction).
A Long Rollout is preferable on fine turf where a higher braking force (Short RO) could damage/tear the turf surface. eg. Golf Course. (i.e. if you take your foot off the pedal at speed the wheels would lock up and skid instead of coasting to a graceful halt.) Try it on grass.
The short RO is more desirable when on higher tractive grip surfaces such as concrete/tarmac.
/ JD 4210 - bogging down ? #12
I understand what it's for but for me it's solving a problem that doesn't exist. It's great if it works for you. Mine has mechanical linkage and it doesn't tear up the grass stopping and starting.
Thanks everyone, I've read the manual and tried some different settings. My application really is what I would consider light mowing and the manual states that's OK in range C. However, I think it's too fast and I get a better cut in B. Plus you guys are the true experts, so I'll be mowing in A or B. At a lower RPM and speed it does seem to bog down less, though I still feel a loss of power, I did not get the indicator lights. I think I prefer the longer roll out. Still learning as I move up from my old BX2200. Thanks for the help.
/ JD 4210 - bogging down ? #14
I never thought to ask you if you made sure the loadmatch feature was on... that's intended to make the C-->B, or B-->A ratio changes so you don't lug the engine. Even with loadmatch on and 30hp at the PTO I can drag in taller grass with a 5 ft shredder, so where the 4210 only spins at 22hp, you'd really feel it with the feature disabled.
/ JD 4210 - bogging down ? #15
Potentiometer is basically a position sensor. Typically on a 0-5v range.
/ JD 4210 - bogging down ? #16
I've had a 4210e for 15 years since it was new. While not the most powerful unit in the world, it has never bogged while mowing grass in A or B range - w/o Loadmatch on. The eHydro was replaced when the unit was new due to some issues. It is possible to have the engine bog down in deep sand - but everything has a limit.
2024 BOBCAT TL619 TELESCOPIC FORKLIFT (A65053)
2024 BOBCAT TL619...
10' Fork Extension (A64912)
10' Fork Extension...
Bush Hog 327R (A64911)
2019 CATERPILLER 249D SKID STEER (A65056)
2019 CATERPILLER...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
AGT QA Pallet Forks (A64912)
AGT QA Pallet...
