JD 4210 losing power after 45 minutes of mowing
   / JD 4210 losing power after 45 minutes of mowing #1
wbeech
Texarkana, Texas
JD 4210
I have an eHydro John Deere 4210, the last three times after 45-60 minutes of mowing, with a 5' shredder, in not particularly deep grass the machine will start to bog down at the slightest challenge. I have not let it die but I am sure that if I kept my foot on the pedal it would have. Runs just great at the begining, fully serviced about 60 hours ago by the dealer.
The temp guage is staying within the green range.
Thanks!
   / JD 4210 losing power after 45 minutes of mowing #2
Tough old beasts that are hard to kill for sure.
Is the governor working at the outset? What about after warmed up? Diesel or gasoline?
   / JD 4210 losing power after 45 minutes of mowing #3
It is probably not impossible that your vented fuel cap is plugged creating a partial vacuum in the tank over time. It is also possible the output to the tank is partially blocked allowing fuel to flow at a less than ideal rate. You can disconnect the fuel line out of the tank and check the flow observing if it slows over time. Of course you'll want to catch it in a clean container for return to the tank.
   / JD 4210 losing power after 45 minutes of mowing #4
Maybe a fuel filter has a slow leak and allows air to get sucked in that builds up over time.
2022 Kubota SVL65-2 (A47307)
2022 Kubota...
2023 Bobcat T66 Track Skid Steer (A49339)
2023 Bobcat T66...
2025 Swict 72in Bucket Skid Steer Attachment (A46683)
2025 Swict 72in...
2018 JLG Skytrak 8042 8,000lb 4x4 Rough Terrain Telehandler (A46683)
2018 JLG Skytrak...
Severe Duty Large Bucket 84" (A43476)
Severe Duty Large...
Stack of 8 Aluminum Wheels (A43476)
Stack of 8...
