JD 4210 4x4 stuck on.
   / JD 4210 4x4 stuck on. #1
Thomas B
Hudsonville, Michigan
John Deere 4210
I have a 2003 John Deere 4210. It has an electronic switch to turn on the 4x4. The switch works, indicator light goes on and off, but the 4 wheel drive stays engaged. Where do I start looking? Anybody have this before?
   / JD 4210 4x4 stuck on. #2
If I remember correctly, engaged is the default position, power turns off 4WD
   / JD 4210 4x4 stuck on. #3
try to back up
willy
   / JD 4210 4x4 stuck on. #4
Sometimes that (backing up) works. You can also lift the front wheels off the ground with the loader, which takes all the "wind up" out. But neither will help if it's the mechanism that's the problem.
   / JD 4210 4x4 stuck on. #5
Check wiring to the solenoid for mfwd and the solenoid.
Thanks for the info but it has been stuck on for over a month and hasn't popped out. Running it around my property isn't a big deal but I have to drive the paved roads sometimes, not a good plan in 4x4. Zebrafive, where would I find that solenoid?
   / JD 4210 4x4 stuck on. #7
I looked in JD parts and could not find it. You may have to trace the wires from the switch, or hoses from the cylinder that engages MFWD back to a control valve.
   / JD 4210 4x4 stuck on. #8
The tractor defaults back to 4wd when the 4wd solenoid doesn't work. It's letter "M" on the schematic. I believe all the solenoids in that stack have the same part # so you might be able to swap them out to rule out it is definitely the solenoid.
   / JD 4210 4x4 stuck on. #9
There's a hydraulic lever under the tractor, between the left front and rear wheel. Most likely it is jammed. It need to be fully extended to disengage the 4wd, or fully retracted to engage it. Try tapping it with a hammer.
2003 Wells Cargo CVG3225 5th Wheel Office Trailer (A53117)
2003 Wells Cargo...
2018 Mack PINNACLE CXU613 Sleeper Truck Tractor (A53117)
2018 Mack PINNACLE...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A53472)
Kubota 24in Quick...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A53472)
JOHN DEERE ROW...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
