JD 420 Front wheel spindle replacement
/ JD 420 Front wheel spindle replacement #1
Westonium
Chehalem Mountain area, OR
JD 4310
I replaced the front tires, and the C clips are worn out. The spindles themselves are a bit worn and I thought "hey maybe I should replace the spindles TOO!"
Well...I look online and they are pricing them at $358 EACH.
:eek:
Suggestions? I could probably get them fabricated for cheaper. Seems dumb. Seems like something I could find elsewhere maybe?
/ JD 420 Front wheel spindle replacement #2
Some pictures would be worth a lot of words here.
/ JD 420 Front wheel spindle replacement #4
:eek:
Could they be the same as the ones on a 430?
If so, can you post a picture, as I have an extra set I bought when my 430 broke the right front spindle. I can measure the spindle diameter, because I think, depending on serial number, they could either be metric or SAE, and just enough different they won't interchange.
/ JD 420 Front wheel spindle replacement #6
Yes, there were 1" and 25mm spindles, bearings and wheels.
SN 362062 and above were 25mm. Below were 1".
/ JD 420 Front wheel spindle replacement #8
:eek:
There are at least 15 used spindles listed on the eBay starting around $50 or so and there are many shops also selling directly all kinds of used JD 400 series parts!
/ JD 420 Front wheel spindle replacement #9
Do you still have a left front spindle laying around? If so I’d be interested in it.
/ JD 420 Front wheel spindle replacement #10
I should have it yet. I'll take a look tomorrow and let you know. I'll measure the spindle size, I don't remember if it's inch or metric.
/ JD 420 Front wheel spindle replacement #11
Sorry, but the one I have is for the right side. I thought I had a pair, but I only have the one for the right side.
Skid Steer Tree Puller (A65640)
Skid Steer Tree...
2015 Weiler P385 Paver (A62613)
2015 Weiler P385...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
Champion X18A Air Compressor (A65640)
Champion X18A Air...
121A (A63745)
121A (A63745)
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
