JD 420 Front wheel spindle replacement
   / JD 420 Front wheel spindle replacement #1
Westonium
Chehalem Mountain area, OR
JD 4310
I replaced the front tires, and the C clips are worn out. The spindles themselves are a bit worn and I thought "hey maybe I should replace the spindles TOO!"
Well...I look online and they are pricing them at $358 EACH.
:eek:
Suggestions? I could probably get them fabricated for cheaper. Seems dumb. Seems like something I could find elsewhere maybe?
   / JD 420 Front wheel spindle replacement #2
Some pictures would be worth a lot of words here.
   / JD 420 Front wheel spindle replacement #4
:eek:
Could they be the same as the ones on a 430?
If so, can you post a picture, as I have an extra set I bought when my 430 broke the right front spindle. I can measure the spindle diameter, because I think, depending on serial number, they could either be metric or SAE, and just enough different they won't interchange.
   / JD 420 Front wheel spindle replacement #6
Yes, there were 1" and 25mm spindles, bearings and wheels.
SN 362062 and above were 25mm. Below were 1".
   / JD 420 Front wheel spindle replacement #8
:eek:
There are at least 15 used spindles listed on the eBay starting around $50 or so and there are many shops also selling directly all kinds of used JD 400 series parts!
   / JD 420 Front wheel spindle replacement #9
Do you still have a left front spindle laying around? If so I’d be interested in it.
   / JD 420 Front wheel spindle replacement #10
I should have it yet. I'll take a look tomorrow and let you know. I'll measure the spindle size, I don't remember if it's inch or metric.
   / JD 420 Front wheel spindle replacement #11
Sorry, but the one I have is for the right side. I thought I had a pair, but I only have the one for the right side.
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
2007 CATERPILLAR D6N HIGH TRACK CRAWLER DOZER (A60429)
2007 CATERPILLAR...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Zero Turn Mower (A59231)
Zero Turn Mower...
