JD 420 Cranks, won't start
   / JD 420 Cranks, won't start
UPDATE: Coil was definitely going bad. I didn't help by leaving key switched to "RUN" for hours :foreheadslap:
Coil primary winding failed resistance test. I don't remember the OHMS, but primary was out of range. Secondary was in range.
Coil was getting HOT when key was on "RUN".
replaced coil, plugs, plug wires. Starts great. Solenoid won't engage the starter gear when hot. We at least have that figured out now though. If anyone has specific advice on hot solenoid issues, I'm listening.
I have to give it a couple of hours to cool if I shut it down hot. Working around that in the meantime.
   / JD 420 Cranks, won't start #12
Maybe the coil is going on that solenoid, the same way it went on the ignition coil primary????
   / JD 420 Cranks, won't start #13
UPDATE: Solenoid won't engage the starter gear when hot. We at least have that figured out now though. If anyone has specific advice on hot solenoid issues, I'm listening.
Is the starter the type were the solenoid forces the starter gear out, or is the solenoid a remote one where it just enables the starter motor?
Richard
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
2018 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2015 Manitou MLT840-115 PS 4WD Telehandler (A50657)
2015 Manitou...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
2020 CATERPILLAR 938M WHEEL LOADER (A51242)
2020 CATERPILLAR...
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
