JD 420 Cranks, won't start
   / JD 420 Cranks, won't start
UPDATE: Coil was definitely going bad. I didn't help by leaving key switched to "RUN" for hours :foreheadslap:
Coil primary winding failed resistance test. I don't remember the OHMS, but primary was out of range. Secondary was in range.
Coil was getting HOT when key was on "RUN".
replaced coil, plugs, plug wires. Starts great. Solenoid won't engage the starter gear when hot. We at least have that figured out now though. If anyone has specific advice on hot solenoid issues, I'm listening.
I have to give it a couple of hours to cool if I shut it down hot. Working around that in the meantime.
   / JD 420 Cranks, won't start #12
Maybe the coil is going on that solenoid, the same way it went on the ignition coil primary????
   / JD 420 Cranks, won't start #13
UPDATE: Solenoid won't engage the starter gear when hot. We at least have that figured out now though. If anyone has specific advice on hot solenoid issues, I'm listening.
Is the starter the type were the solenoid forces the starter gear out, or is the solenoid a remote one where it just enables the starter motor?
Richard
Wells Cargo Enclosed Trailer (A50324)
Wells Cargo...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A48082)
2016 Toro...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
2022 Case IH Steiger 420HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A51039)
2017 Yale GLC050VX...
