Comparison JD 4120 with 400CX Loader
/ JD 4120 with 400CX Loader #1
dddowns
Amherst, VA
JD 4120
What are the pros and cons of the 61" vs 73" bucket?
/ JD 4120 with 400CX Loader #2
None, get the 73.
The 4120 is 6' wide with the wheels set to narrow. I would not want a bucket more narrow then the outside of the track.
The 73 has worked perfect for me on mine.
/ JD 4120 with 400CX Loader #3
Stick with the 73" bucket for reason stated above, if you need to get into narrow space quite often a smaller tractor may be a better option.
/ JD 4120 with 400CX Loader #4
Be aware the default bucket which JD puts on their FEL is not sturdy enough for heavy lifting, etc. If you want to use the FEL to do chores like pushing over tree stumps, you should go to the heavy duty/reinforced bucket. Because the regular bucket's lower lip will bend easily under stress. It is sufficient only for moving light duty load such as bark, sand, dirt, snow, etc. I learned the hard way, which is always fixable by opening up your check book....
Jim
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
FUEL TANK (A68842)
FUEL TANK (A68842)
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
1998 INTERNATIONAL 2674 6X4 T/A VACUUM TRUCK (A66091)
1998 INTERNATIONAL...
2015 Nissan Leaf Hatchback (A64557)
2015 Nissan Leaf...
