Comparison JD 4120 with 400CX Loader
   / JD 4120 with 400CX Loader #1
dddowns
Amherst, VA
JD 4120
What are the pros and cons of the 61" vs 73" bucket?
   / JD 4120 with 400CX Loader #2
None, get the 73.
The 4120 is 6' wide with the wheels set to narrow. I would not want a bucket more narrow then the outside of the track.
The 73 has worked perfect for me on mine.
   / JD 4120 with 400CX Loader #3
Stick with the 73" bucket for reason stated above, if you need to get into narrow space quite often a smaller tractor may be a better option.
   / JD 4120 with 400CX Loader #4
Be aware the default bucket which JD puts on their FEL is not sturdy enough for heavy lifting, etc. If you want to use the FEL to do chores like pushing over tree stumps, you should go to the heavy duty/reinforced bucket. Because the regular bucket's lower lip will bend easily under stress. It is sufficient only for moving light duty load such as bark, sand, dirt, snow, etc. I learned the hard way, which is always fixable by opening up your check book....
Jim
JOHN DEERE 5103 TRACTOR (A57192)
JOHN DEERE 5103...
2003 Big Tex 10PI...
2016 Dodge Charger SRT Hellcat Sedan (A53424)
2016 Dodge Charger...
12" PIN ON BUCKET (A52707)
12" PIN ON BUCKET...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
