JD 4100 Front Loader Sluggish
/ JD 4100 Front Loader Sluggish #1
Angy
John Deere 4100
My JD 4100 front end loader is sluggish
/ JD 4100 Front Loader Sluggish #2
Is your hydraulic fluid at the proper level? What's the position of your three point control? If it is in the full up position that can slow the front loader. If that is the cause there's a simple adjustment to fix it. After these it's possibly a filter, screen, or suction line problem.
/ JD 4100 Front Loader Sluggish #3
That model has a cleanable filter in the sump. Take it out and scrub it up. That may or may not be the fix, but it is where you have to start. While there, take a look for an old weathered hose that may be causing a air suction leak for oil moving between the sump up to the hydraulic pump.
/ JD 4100 Front Loader Sluggish #4
Could be wrong viscosity hydraulic fluid. MUST be LO-VIS. Don't ever use generic hydraulic fluid in the JD or Kubota tractors.
/ JD 4100 Front Loader Sluggish #5
Angy
Did the loader suddenly start moving sluggish or has it slowly been getting worse?
If suddenly does it sound like the tractor is straining when trying operate the loader?
iDrive TDS-2010H...
2023 John Deere 835R (A64119)
2023 John Deere...
New - Front mount rototiller
New - Front mount...
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
