JD 4100 battery light
/ JD 4100 battery light #1
johndeere4720
Lambertville MI
john deere 6430p 4720 and 4100
Hi, I have a JD 4100 and the battery light has been flickering on and off when the the pto is engaged. It just started doing it this week. I really need to cut the yard. Is it ok to mow with the battery light flickering on and off?
/ JD 4100 battery light #2
Have you checked the battery voltage with a meter?
The voltage meter said that the battery is putting out 13.1 volts.
/ JD 4100 battery light #4
Is that with the engine running?
I looked at the schematics for my 4110 (newer model of your 4100) and don't see how the two (battery and PTO)lights are related:confused:
My gut feeling is that the PTO clutch is robbing enough power to make the light flicker because the battery or alternator is bad. Can you duplicate the flickering by turning on the headlights?
No that was with engine off. I will try flickering the headlights tomorrow.
I have had to have the alternater replaced along with the battery though.
/ JD 4100 battery light #6
My gut feeling is kennyd is right on the $$$$$$$
/ JD 4100 battery light #8
I think KennyD means it is drawing enough power that the battery and alternator problems are more evident. I would recomend you test as was mentioned, check voltage while running at a fast idle with and without headlights on and pto engaged and disengaged to determine if the electrical system is the problem or pto clutch.
With the engine running off hand I would expect to see about 14 to 14.5 volts with the lights on or off.
Steve
/ JD 4100 battery light #9
Steve
Thanks Steve, that is exactly what I meant.
I was getting 12.3 volts with the headlights on and 13.6 volts with them off. I did test the voltage at 1500rpm and was getting 14.1 volts. By the way, all the tests were from the battery.
I was not able to test the voltage with the PTO on because I didn't have an operator. I have a feeling that the alternator is going bad.:mad:
Steve
/ JD 4100 battery light #11
You can engage the rear PTO while off-the-seat by lifting the seat and then pulling the seat switch UP-at least that's the way my 4110 is...
/ JD 4100 battery light #12
Try to perform the test completely so we can better determine your problems.
steve
Well, I was able to engage the rear PTO at idle and was getting 13.6 volts, then I shut off the PTO and was still getting 13.6 volts.
/ JD 4100 battery light #14
Was that a fast idle? If it was that seems low to me. On your tractor is this a belt drive alternator? May want to check the belt tension. If you raise the engine speed to a fast idle it should rise above 14.0 volts when battery is fully charged.
13.6 volts will allow for a slow charge to your battery, if you can add the pto and lights at a fast idle and still maintain this you might be okay. I doubt from your measurements that the pto clutch is the problem and you should be able to mow with it without harm. I would think your alternator is not keeping up but a bad battery can drag down the voltage too. I think it would be wise to take the battery in and have it load tested to help eliminate it as a source of the problem. If the battery checks out good and is replaced fully charged then you should get readings near 14.0 volts when running. If not then I would remove the alternator and have it tested and or repaired.
Steve
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7866 Miles (A63689)
2019 Cadillac XTS...
2024 CRUISER RV SHADOW CRUISER (A67714)
2024 CRUISER RV...
1994 KENWORTH T600 (A67714)
1994 KENWORTH T600...
2026 KH72 72in Hydraulic 4-Way Clamshell Bucket Skid Steer Attachment (A66734)
2026 KH72 72in...
2012 CHEVROLET IMPALA CAR (A66091)
2012 CHEVROLET...
2019 Ford Transit Connect Passenger Van (A66736)
2019 Ford Transit...
