JD 4100 3PH arms hitting tires
Status
Not open for further replies.
   / JD 4100 3PH arms hitting tires #1
acs55812
Duluth, MN
I haven't had time to check the owners manual yet but has anyone had a problem with the 3PH lower arms hitting the bars on ag tires if something (brushcutter) swings to one side?
   / JD 4100 3PH arms hitting tires #3
Didn't this question just get a good response for you? /forums/images/graemlins/confused.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/confused.gif
   / JD 4100 3PH arms hitting tires #4
actually the one in attachments was a mistake----I meant to put it in a JD forum but screwed up /forums/images/graemlins/confused.gif
   / JD 4100 3PH arms hitting tires #7
I have a 4110 which is almost the exact same tractor. You need to adjust the turnbuckles to make it fit right. And you also need to put the pin in the rear hole on the arms so it will pick the brushcutter up high enough. I have the R4 tires and it don't hit them even.
   / JD 4100 3PH arms hitting tires #8
Status
New/Unused CFG Industrial QK20R Mini Excavator (A51573)
New/Unused CFG...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A53472)
2006 Magnolia Dry...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
