JD 4100 3PH arms hitting tires
Status
Not open for further replies.
   / JD 4100 3PH arms hitting tires #1
acs55812
Duluth, MN
I haven't had time to check the owners manual yet but has anyone had a problem with the 3PH lower arms hitting the bars on ag tires if something (brushcutter) swings to one side?
   / JD 4100 3PH arms hitting tires #3
Didn't this question just get a good response for you? /forums/images/graemlins/confused.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/confused.gif
   / JD 4100 3PH arms hitting tires #4
actually the one in attachments was a mistake----I meant to put it in a JD forum but screwed up /forums/images/graemlins/confused.gif
   / JD 4100 3PH arms hitting tires #7
I have a 4110 which is almost the exact same tractor. You need to adjust the turnbuckles to make it fit right. And you also need to put the pin in the rear hole on the arms so it will pick the brushcutter up high enough. I have the R4 tires and it don't hit them even.
   / JD 4100 3PH arms hitting tires #8
Status
2007 KENWORTH W900L DAY CAB (A52472)
2007 KENWORTH...
2020 John Deere 8R 410 MFWD Tractor (A53342)
2020 John Deere 8R...
NEW 78'' Wolverine Skid Steer Land Leveler (A53002)
NEW 78'' Wolverine...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A53472)
PENDING SELLER...
2023 John Deere 6R 155 MFWD Tractor (A53342)
2023 John Deere 6R...
2013 KENWORTH T800 DAY CAB (A53426)
2013 KENWORTH T800...
